Deck chute conditioner
  • Deck chute conditioner
    Is there anything out there to remove the old Brunswick deck chute conditioner from the chutes that are peeling ect.I been using steel wool and lots of elbow grease.It seems to be hanging up pins alot during the Summer Humidity ect.Dont wanna recoat them.send Help.
    Re: Deck chute conditioner
    there aint alot you can do really just Pitch the chutes for the most part.Learn from past mistakes..
      Pitch them and try some of murrey's new chutes.
        I've found that some rough sand paper streight up and down the chutes work quite well...
        the just use your cleaner and scrub them down.
        I did this a year ago to most of my chutes and I havn't had any problems since, I also clean the deck chutes twice a week
        Tech
          you might try lacquer thinner. don't know of anything else.
            Larry,,
            just a thought but wouldnt using lacquer thinner on the deck chutes send either the rubber or the urethane brittle??? not sure but was just a thought.
              maybe you can try using mineral spirits on them...just a thought!
              ß
