Turrets,pits,etc.What ya doin?
Been doing turret work such as....check/replace short links when needed,belts,remove time delays,check slides,replace upper portion of drop link(have found many worn in hole),stop lever checks,replace index trip lever spring AND stud(many worn and bad),interlock probe area checks and replace those links too(some bent,sloppy),c-lever bearings,index bellcrank checks.,etc.,etc.HIGH lineage center.,2 if not 3 leagues back to back at times.,then packed open play.YIKES!Also doing...pit checks and re-greasing,edgeboard repairs,lower guide roller checks/replacements,uppers too,Whats on your game plans??Plus...teaching a new guy at another place on how to do's. Is'nt this job fun!?Ahhhh...summer work. lolTags: None
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
