Just wondering what everyone uses to clean ballwheels. I used to use DBA 008, but environmental regs make this no longer feasible. Any suggestions? Alcohol and acetone just don't seem to work very well.
What do you use to clean ballwheels?
Re: What do you use to clean ballwheels?
I personally prefer cv88,its a super all purpose cleaner but you can use your lane cleaning machine cleaner.I do'nt dilute it for ball wheels and i spray some on the wheel then take a clean rag and wipe it down until dry.I have stripped my wheels too by spraying them then using a softer scotch brite pad(some can be rough)i put good pressure on the pad,let wheel turn about 5-6 times then wipe off and then re-spray wheel and wipe totally dry.Sure maybe for some it's more work BUT the results have been outstanding!Balls get picked up by wheel itself w/o even using kickers!You'll really see the crud/build-up come off w/the pad method! I strip them about every 2-3 months due to high lineage.It really does work great!And....NO...it wont hurt the ball wheel!!!
Gibh:
Boy is this going to be one active thread.
I for one don't favor anything flammable, static will set off an alcohol rag, whilst in your hand, then you drop it because it's hot, but not readily apparent that its on fire and it gets dropped on pins, carpet and or carried up cross conveyor.
Its been derigueur, since the demise of lacquer finish, to clean ball wheels and lift rods daily, with a solvent that was both safe for use on rubber and had a high flash point.
Especialy when used by lesser trained personnel.
Anxious to see these replys, because it's a very active topic.
Luck in all weathers:
Roscoerfm
This could be interesting and informative indeed. Okay we use ZEP Formula 50 for all machine cleaning and degreasing. It works quickly and removes the oil and grease. The decks are even sprayed down with it before washing them down at the car wash. Makes them look brand new. Even have a shallow bucket filled with it which acts as a parts cleaner.
The Brunswick maintenance manual recommends just a clean dry rag which works well..(not a shop towel)terry cloth and alot of pressure works good for me but i have always used a nonflammable water based degreaser.wring out the rag hold firmly on ball wheel and then a clean dry rag after that and wheel will be squeaky clean.
I use a hard surface cleaner that I buy locally from around town. I use that to clean almost everything.
the other thing I've done is to glue carpet strips onto the ball wheels. 2 or 3 strips about 3 ft long each pick up the balls up effortlessly.
I have to scrub them at least twice a week... but at least I don't get any more ball spins!!
Tech
jacks,
zep is a great company!
we've used zep shoe spray for eons. we've also had a drain clogged for years. had roto-rooter and all out but nothin worked to long. when at the Price Club saw this "zep drain cleaner" figured what the hell. Our three year drain is fixed!!!
anything that says zep ill buy...exept beer
Alrighty, this is going to sound strange, but I've found out it works.
Normally we use a dry terry cloth to clean those ball wheels. but whenever I'm having a problem w/a lane, I grab two towels. On one I put a little bit of Goop Hand cleaner, and leave the other one dry. I put the goop on the ball wheel, let it spin two or three times, then wipe it off well. This tends to make the ball wheel tacky. It's great, and tends to get rid of ball calls until I get a chance to adjust the ball lift..
P.S. This doesn't work w/all hand cleaners, you might end up w/a bigger problem than you started w/.
[This message has been edited by bcw757 (edited 08-21-2000).]......
