Used Parts?
  • Used Parts?
    Does anyone out there know where i can get some medium sized main motor pulleys. I have 20 machines
    I currently have the high speed pulley, do you guys recommend using the slower pulley or stick with what i got??
    Re: Used Parts?
    I always slow mine down,Quality bowling sells a motor pulley that keeps the elevator speed at A-2 speed but slows the gearbox down to jet back speed its
    their special slow down pulley,dont have the
    part number handy.As for used parts you might try Newell's bowling supply 800-796-2200.They often have used parts.
      Re: Used Parts?
      I currently have 18 jet back "special" pulleys listed in the classified ads. These pulley will slow down an A-2 and will keep the elevator running at the slower speed. Interested? E me.
      billman
      let me be myself
        Re: Used Parts?
        hey shannon call larry at tri-state bowling 1 800 872 6822 he might have some more pulleys for you tell him jeremy sent you good luck
