geneva plates
  • geneva plates
    hey guys ,i have 2 machines that the moving deck wants to jam when it shifts to the full rearward position. one machine was actually not setting new pins.so for a quick fix to get them going i pulled the cam followers off the one side. it worked fine the rest of the day.then when i got to look at it i found that the moving deck was bowed and i put on the zot deck saver, pulled it straight and put two new geneva plates on and new followers on. THE DECK JAMMED! so i put the old plates on and smoothed out the groove on the 7 side. it seems to be o.k. now but , am i missing somthing here ? give me your input. is somthing shot that i should look at? thanks, laze
    Re: geneva plates
    First thing to do is find out exactly where it binds, if where the two sets of rollers switch, I'd take a look at the roll pin in the 10 pin end of the shaft. Had one shatter once, caused the two sides to pull out of time.
    Kevin
      Re: geneva plates
      I had a similar problem with one of my machines.
      I discovered the moving deck wasn't sitting streight on the rollers, don't ask me how!
      one of the Geneva plates were bent and the cables were frayed...
      all I can suggest is check out the cables, they might be jaming.
      other then that... the deck rollers all ok?
      let us know how things work out... I have only just corrected this one myself. I might still be needing ideas
      Tech
        Re: geneva plates
        Also might want to check the moving deck pulley for dryness or bad bearings.
          Re: geneva plates
          Lubricate the needle Bearings on the rear deck shaft.If they are dry the deck wont shift properly.I mean the ones by the brass spacer washer.Also a scissors pin can come out or a deck chute bolt being loose and catching deck maybe a headpin one...Good Luck.
            Re: geneva plates
            Laze3:
            You might also check the moving deck casting, just forward of the geneva at first web. Quite possibly cracked, allowing the geneva plate itself so slope downard.
            Roscoe
            rfm
              Re: geneva plates
              well guys i checked out everything i could think of , and all your sugestions but there is nothing visably wrong. the machine that i smoothed out the plates on has been workong great. the other machine is still ok but i can hear the deck want to catch when it shift rearward. i still have to investigate further.my superiors have had me so bust doing other stuff that i haven't had the time!
                Re: geneva plates
                maybe you need to tweek the moving deck a little more and i would check the shaft 12-350032 maybe the bearings are dry or here is one more thing a bolt from a spotting finger or a deck chute may have droped well good luck j b
                  Re: geneva plates
                  Hey Laze3
                  When the deck jams get a flashlight and see if one of the geneva rollers has bottomed out against the cam.
                  Usually the geneva rollers will be straight up and down and one of the top rollers will be jammed against the top part of the cam slot.
                  If it looks like this try straightening your deck a little more, I used to add washers between the moving deck and the long black slide that rides on the steel rollers to shim up the deck to give the geneva rollers more room to roam.
                  Let us know what you find.
                  grambo
