Pivot link inverting
  • Pivot link inverting
    Had a machine bust a hook selector bearing last night, cause was that the pivot link had flipped over and the trip rod lever was binding against the cross brace collar that tells the rake when to sweep (never noticed it because the zot triggered the machine every time)
    What causes the pivot link to flip over, and what can I do to prevent it from flipping over in the future. Definitely a problem that I'd rather avoid, but have only seen it in very isolated cases, never seen it while it was happening.
    Thanx in advance:
    Kevin
    Re: Pivot link inverting
    Kevin...
    If you're talking about the pivot link on the "C" levers (by the shotgun) we drilled (I hate to use that word for fear of adding fuel to an already burning fire in other threads, but anyways) two holes...one on each C Lever. Ran a 1/4 - 20 bolt through in front of pivot link and fastened with lock nut. Works great for those times when a ball is idling on the lip of the pit frame and the cushion closes on top of it. I wish I still had access to those pinsetters so I can take a snapshot and post it. Anyway, hope this helps and is not confusing.
    Kat
      Kat:
      That's exactly what I was after ... but where on the C levers to drill, a little before the pivot link could get past vertical, or allowing it just enough motion to do its job (fire the gun), or somewhere in the middle??
      Hear you on the other thread, LOL!!, but in this case, saving busted guns and hook selector bearings justifies this "enhancement", IMO. While I can change one fairly quick (now that I do them on the machine, thanks to another bowl-tech suggestion) It's one repair I can do without, since it's needless.
      Thanx
      Kevin
        Kevin....
        It's a judgement call. Whichever works for you. We had ours about 1/4" from the pivot link. Just be sure to align the holes so that when you put the bolt in it doesn't look cheesey or a hack job. As long as you can grab the trip casting and trigger the shotgun with no binds, you're set. Oh, BTW, one word...when tightening, don't overtighten so that the gap between the "C" Levers decreases and bind up against the oilites in pivot.
        Best of luck!
        Kat
        (wishing he still had his A-2s )
          K.L.
          Simpliest fix is to drill a 1/4 hole, midway in the travel portion of the slotted link, through both the top and bottom and install a roll pin or bolt thus preventing overcenter travel of linkage.
          Be assured no other problems will result from this jury-rig, and it will permanently put to rest broken H members.
          However in the current climate prevailing, this advise could be construed as ignoring other adjustments, which is patently B.S.
          New installations were prone to this problem, most all rake trippers have some such device, or they replace said parts on a regular basis.
          Roscoe
          rfm
            Hey Roscoe
            You are right that this is not a rig but a permanent repair to keep the shotgun trip linkage from flipping.
            We installed mini A-2 conversions at our center and Brunswick gave us top slotted links with a shorter slot so the linkage could not flip over.
            They probably stopped making them because I never broke any shotgun trip linkage with this type top fitting.
            Grambo
              Also check your pit cushion Shocks that they still have good resistance in them.Or the ball will slam under the cushion causing this problem too.
              John
              John
                Heya!
                I did this to my machines about a year ago. I almost forgot what inverted trip links looked like...(almost)
                I drilled a hole in the C levers about halfway from the pivot link center (where the spacer is), to the edge of the C-lever.
                Put in a 1/4-20 bolt, and tightened a nylon locknut just tight enough to keep the bolt from moving/rattling around.
                Have not had one problem with any machine, and havent had to change the "H lever"
                as roscoe calls it. Hmmm, kinda like that name.
                Wookie8662
                  Shamefowjze:
                  Now, now- were trying our best here, not to live up to the reputation recently assigned to us, please cooperate in these delicate negotiations.
                  Your friend
                  Roscoe
                  rfm
                    KL Kevin,
                    Don't go drilling any holes just quite yet...try this first. Grab an old (or new) urethane roller from your pit cushion linkage (12-252351). Insert it into the slotted link and put a small wire tie to hold it in there. Then "forget about it". You'll never see it happen again. No drilling required.
                    Steve
                      Steve:
                      You will find that the wire ties will eventually break, even the 1/4 in versions.
                      My opinion is spend the time, do it right, and never go back to that area. Inverted linkage can cause not only triggering problems, but also rake and deck holding hook problems, some of which can result in damage, thats very costly, an inverted link can easily keep the deck holding hook from fully engaging the deck pin, and when the turret dumps, which it will at that height, the deck will find the lowest thing to stop it, being a single pin, or the end of the lowering link.
                      Perhaps not enough has been said about the dangers of the deck holding hook. I know personally of two people killed, from incorrect deck holding adjs., or worn holding hooks.
                      The most dangerous thing a mech. on a Brunswick pinsetter can do, is to get under a deck, while machine is between 90 and 180 degrees, second ball. All Overtravel machines are dangerous, on second ball.
                      Deck holding hooks, and there wear factor at the sharp point is one of the very first things I determine upon evaluating a machine.
                      I consider the deck holding hook the most deadly part of the machine, the rake can kill you, if you are dumb enough to be in a running machine, but the hook can do also, with the machine shut off. I know this is a long post, but I feel strongly about this subject.
                      Perhaps some of the more seasoned mechanics, will add to this post,with other dangers, that new mechs, or anyone reading our posts
                      can benefit from.
                      David, start it out with things not to do ! We all assume every one has been to school, thats not the case.
                      rfm
                        roscoe,
                        i apologize for my previous comment in regards to the duct tape. i agree with the roll pin "modification" to solve this problem. but it appears as if this individual is on a personal "by the book" crusade. perhaps fueling the fire is not the best thing to do in this situation. you made a good point about the deck hook saftey issues. perhaps another thred should be started on that subject alone. my sympathy goes out to your friends that left us in "the line of duty". i hate hearing about that kind of stuff........alex
                        Cloth: ShamWow!
                        Machine: Johnny 5
                          kl kevin
                          You might look at your carpet, make sure carpet clamp is not higher than carpet, also check carpet clamp to make sure it is not even or lower than ball wheel. I have seen this inversion caused by a ball not returning, gets stuck under pit cushion so when cushion drops ball prevents this and inversion can happen. also make sure pit cushion raises high enough for ball to go under cushion without touching cushion. Any place a ball can get stuck can cause inversion if not by one ball but maybe two or more.
                          Roscoe is right the inversion can cause many problems some weird some unfortunate. Lets face it these machines are hostile, lets make ever effort to make them safer for all concerned.
                          We all know how hard it is to adjust all machines to pick up 50 years of bowling balls without problems. Most of us try our best to get balls back as we do not like chasing balls or fixing problems caused by balls not returning. If your center averages 30-40 lines per bed per day about 25,000 balls are thrown per day, all kinds of balls.
                          I do not have this suggested fix on my machines, but I believe this will work.
                            Hey Roscoe
                            I wrote awhile back that all mechanics should lock out the machine before working on it to protect themselfs and to conform to OSHA regulations.
                            I think everyone should adhere your advice and NOT go under the deck when it is being held on the hook.
                            And my advice is to turn the machine off at 2 places if locking out the machine is not possible.
                            Let us all work safely!!!
                            Grambo
                            ps In the Graingers catalog there are lock out devices that will fit over the pinsetter electrical box drop cord.
                              Roscoe
                              and bolts break and roll pins fall out...lol. I suggested a quick and easy solution that doesn't require weakening a piece of metal by drilling a hole into it. It's not the only answer...just another way of doing it.
                              Just my 2 cents worth...
                              Steve
                              [This message has been edited by JBEES (edited 07-19-2000).]
                              Ball Returns Shorted Out?
                              Trip rocker arm
                              Lower ball cushion board
                              Backend motor plug
                              82/70 combi motors
