Zot -Deck saver
  • Zot -Deck saver
    has anyone used Zot's 'deck right deck saver'??
    I've got a deck that is a bit warped and is causeing a few problems... I am just wondering if this thing is worth the money
    Re: Zot -Deck saver
    I too am wondering on this.I found a deck that needs a kit installed,seems bowed on the 7 side and we get some respots that i think are from a bowed deck..all else is good.Yah...does this really work and is it fairly easy to put on?
      Re: Zot -Deck saver
      Gentlemen:
      They work great, are very easy to install. they won't correct a cracked deck at webbing.
      Roscoe
      rfm
        Re: Zot -Deck saver
        the deck I've got that has bowed was cracked a while back and welded back together. that was long before I goit to this centre.
        will this make much difference??
        Tech
          Re: Zot -Deck saver
          Aussie:
          Should only help to improve movement, since its already been welded, as the straightner does pull up on both sides as it pushes down the middle
          Roscoe
          rfm
            Re: Zot -Deck saver
            The kit works Grrrreat!!
            billman
            let me be myself
              Re: Zot -Deck saver
              just as a quick up date on this... I installed the deck saver and it snaped on me!
              I was tensioning it up when it let go. luckily it has worked well enough to streighten the deck enough to move freely, I am just hopeing now that I get the replacement before it goes back out of shape again!! lol
                Re: Zot -Deck saver
                [/QUOTE]
                The trick is not to try to tension it all at one time. Do a little each day to allow the deck to adjust itself. Within a month you should see the difference. PJ
