3 2/10 FUSE
  • 3 2/10 FUSE
    I have a pinsetter that is blowing the 3 2/10 fuse. takes it about 30 sec. to blow when machine is turned on. Have checked everything i know. Any ideas ???
    Re: 3 2/10 FUSE
    Check your 1st and 2nd ball light's FIRST, then unpluge your m/c plug going up front,then your ball acc.
      Re: 3 2/10 FUSE
      Look at the fuse. Sometimes you can tell what to look for by how the fuse is blown. Check any and everthing dealing with the low voltage system of the machine. Also check the fuse holder itself.
      Happy Hunting, billman
      let me be myself
        Re: 3 2/10 FUSE
        one thing to check is for a pinched wire aound the area where the rake sweeps it will pinch the wire going to ball Booster or acclerator.Usually its under the rake safety stop bracket area under itsalong the frame. This happened to me many times over the years.
          Re: 3 2/10 FUSE
          Possibly a reset wire grounding to ball track, easy to check, turn on both lanes, send balls through from back with no bowling going on ...
          Where in cycle does it blow, if around 270, setting new pins, possibly hosed frame counter or wiring.
          Let us know:
          Kevin
            Re: 3 2/10 FUSE
            ID PUT MONEY ON THE 1ST BALL LIGHT ON THE MASKING UNIT I HAD THE SAME PROBLEM A FEW YEARS AGO
              Re: 3 2/10 FUSE
              Majic:
              One other thing, if someone has just changed the motor start relay. make certain the wiring to the coil was not interchanged, in that wire #35 /#18 are together, wire #54 / #12 are together it makes no difference which side of coil their placed, only kept together
              Roscoe
              rfm
                Re: 3 2/10 FUSE
                Thanks guys. The problem was in the #1 ball light socket. Couldn`t tell by looking at it. changed the socket, works fine.
