Tiger Strips
  • Tiger Strips
    Any one else having problems getting a tiger strip to stay on a ball wheel. Ive cleaned the ball wheel repeatedly before applying the strip, and gone back a couple of hours later and the thing is laying across the motor mount shaft. Just got some more in last week hoping they would work a little better, nope! You'd figure for 8 bucks a strip they would stay on for more than 1 night. Having mass customer complaints because they are leaving the adhesive on the ball wheel and transfering it to the customers balls. Maybe if you buy a pack of 3 they will start giving you a free can of contact cement LOL.
    Jerrid
    Re: Tiger Strips
    You are correct about the darn things coming off. I talked to Zot, and was told they had fixed the problem. That was in March. I guess there is still a boo-boo in the glue-goo. If you have alot of them, call PJ @ Zot
    billman
    let me be myself
      Re: Tiger Strips
      or stop buying the DARN things. Try another idea...there have been many good ideas posted in this forum. Try one and see how it works for you...you know these don't.
      Just my two cents worth...
      Steve
        Re: Tiger Strips
        a very cheap and easy ulturnative is just plain old carpet.
        we had the centre I work in's carpet relaid up the front and we got all the cast away carpet...
        cut them into approx 3 -4ft strips the width of the ball wheel and glue them on.
        if you use the right glue they'll stay there for ages!
        I'll go along every couple off weeks and tidy up the few frayed areas but I don't usually have to replace any for well over 6 months!
        give that a go, cast off carpet is generally cheap!
        Tech
          Re: Tiger Strips
          I have tried everything you can imagine on a ball wheel to get a ball back. It does not matter how perfect your adjustments are, there is still that 1 ball that will not go up. The main reason I bought the tiger strips is for my night time mechanics that dont have the downtime to put contact cement on a ball wheel. Ive been saving the old strips, stripping off all of the adhesive and then re-applying them with contact cement. This seems to work well. IMO They are a good product just a little bit overpriced, rubber strips hold up great, just seems to be a problem with the adhesive, but now I have to go remove adhesive from about 25 ball wheels.
          Jerrid
            Re: Tiger Strips
            We have been using the product from Vantage... I think it is called ss24 or something like that. It is not as thick as the tiger strip and it is a bit wider. I get it in a 24 ft. roll and cut them to 18-24 inches. I clean the wheel with chlorinite or acetone, then peel and stick. they last about a season. We used to use carpet, and although it does work, if you get a ball stuck in the lift rods, the friction will make short work of any coverstock... Also, I really got tired of the strings and fuzz being carried all over the pinsetter. I used tigerstrips back in 91 or 92 and had good luck with them. I guess the quality control people dropped the ball...
            41 years and still learning....
            lanedoctor@hotmail.com
              Re: Tiger Strips
              Hello,
              New to the site, wanted to add to the discussion about Ball wheel kickers.
              I use two things with great success.
              One is the Vantage 100SS-24, it comes in a 24' roll so you can cut it to whatever lengths you want. It also has a very good adhesive, Mine wear off before they ever peel off.
              The other thing we use, if we can find a hardware store that sells, it is rolled cork. You have to cut this to length and width and apply it with contact cement, but the price is around $5.00 a roll.
                Re: Tiger Strips
                I agree with Jerrid. Although the Tiger Strips are the best at moving balls up the rods, they come with some piss-poor glue on 'em.
                We have a bunch of them laying on the bench waiting to be 'reglued'. Some mechanics that work here still prefer the carpet, though. Every other lane has pieces of carpet DUCK-TAPED ON! Crazy old man.
                [This message has been edited by Jambu (edited 08-08-2000).]
                  Re: Tiger Strips
                  I have had good luck with ball wheel liner from Tech-Line. Its about $3 per foot, comes in a 25' roll. I put a 20" piece on the wheel and when it starts to wear, I apply another piece behind the first one. It lasts about 9 to 12 months. PJ
                    Re: Tiger Strips
                    We have some issues with the adhesive on the Tiger Strips. We have had samples sent direct to 3M and have come up with a solution to the problem if anyone is still having problems please contact me at ZOT.
                    PJ
                    P J Rosendahl
                    www.bowlingfactoryoutlet.com
                      Re: Tiger Strips
                      seems a few years back, I swore by the Tiger Strips, they were the best thing since sliced bread.... now I'm in a new house, and I swear I'd have better luck getting WD40 to stick to the ballwheels... Figured these wheels had just been abused too much, but I'm starting to believe that the Tiger strips have instead become chicken shi*.... umm... I mean, kitten strips..............
                      Thanks all for the extra boost in my suspicions... what do these guys manufacture these things in a kindergarten class??????
                      Grr
                      Oldsmagnet -- Sidney MT
                        Re: Tiger Strips
                        i just put some tiger strips on! And they are staying on too...so far! Spray the entire ball wheel while the pinsetter is on. Take a rag and clean the hell out of it then dry the ballwheel. Turn off the pinsetter...apply the tiger strip on. What kind of cleaner are you using? I use System #407 from Poly-Chem. It has...so i'ver heard...a drying element in it. Try it!!
                        ßA
