HAD ONE OF MY MACHINES START ACTING UP. WHEN THE DECK GOES DOWN TO PICK UP STANDING PINS, THE MOVING DECK MAKES A SLIGHT FORWARD MOVEMENT. BEFOR DECK MOVES GENEVA ROLLERS ARE AT AN ANGLE AND THEN AFTER DECK STARTS TO LOWER AND THE SLIGHT MOVEMENT THEY ARE AT THE STRAIGHT ANGLE WERE SUPPOSED TO BE.
CANT SEE ANYTHING VISIBLE THAT MIGHT BE BINDING OR HOLDING IT BACK A TOUCH.
I DO THINK IT IS OK NOW
THANKS TO EVERYONE WHO HELPED POINT ME WHERE TO CHECK THINGS OUT.
[This message has been edited by JEFF KUHNLE (edited 08-12-2000).]
If your are talking about when machine starts the cycle, then check your gearbox timing and check the 1:1 square key. The key maybe broken, this will cause a slippage of the scissor-deck cam as will the rake cam may rock also. If this is not the problem then maybe the 4;1 bronze gear is bad. I would bet on the square key.
Jeff,
You are describing a problem that exists on many older machines...usually a 1:1 shaft or key for the moving deck scissor cam as Larry and PC have mentioned. Also, check the roller bearing on the moving deck cam follower. Have seen enough wear to cause the contact point of the bearing change relative to the moving deck cam moving that contact point down.(laggging behind) This is very rare and very easy to check. It will move quite a bit on the shaft. It probably isn't that, but just another possibility.
Just my two cents worth...
Steve
If the moving deck makes a small forward shift
just as it starts to move it could be as simple as the gearbox clutch lever adjustment being out of adjustment and stopping early.The 2 most common symptom of that problem is when the deck shifts when the pinsetter starts and when pins are in the turret and don't drop into the deck buckets until the machine starts to cycle.
Good luck.
[This message has been edited by David Johnson (edited 08-11-2000).]
I agree on all these replies.
Watch your moving deck/scissors cam while the machine is going through a normal cycle.
If you notice that the cam hesitates or pops forward than you probably have a broken key.
If the cam stays solid check your gearbox clutch adjustment.
On a model a the rake crank should be in a straight line with the rake crank link.
If you have a-2s the crank link should be in a parallel plane with the rake crank.
The crank link would be straight at about the top of the washer of the 4-1 where the crank bolts to the 4-1 shaft.
Hope this helps.
Grambo
My deck started shifting forward at cycle start and when picking up pins...it would set the pins down then they would all wobble badly.Found the cover for 1-1 was cracked so the 1-1 was replaced.No more troubles.Man that cover was toasted!Be sure ALL mounting hardware is tight so as not to have this happen to you too!
HEY TO ALL
ALL OF THE REPLYS I GOT BACK HELPED. I STARTED AT THE MOST SIMPLE AREA TO CHECK OUT AND IT WAS A SLIGHT ADJUSTMENT IN THE GEAR BOX CLUTCH AND TIMING.
