New A-2 clutch reset lever
  • New A-2 clutch reset lever
    I am rebuilding a A-2 gearbox and i have treid installing the new clutch reset lever 12-102176-000, when engaging it the Clutch release 12-100708-000 hits the 4:1 housing. reinstalled the orignal reset lever all is ok. any on tell if their is anything else I have to do or replace. the gearbox housing has J-69### on it, our pinsetters have 29###.also when matching the old and new levers side by side the new one at bearing end doesn't seem to be in the same position its slightly forward.
    [This message has been edited by Errol Pedersen (edited 08-29-2000).]
