THE RAKE
  • THE RAKE
    HELLO EVERYBODY
    I HAVE ONE OF MY MACHINES THAT IS RUNNING FINE EXCEPT THE RAKE.
    I HAVE "BRUNS. As AND WHEN THE DECK IS COMING DOWN TO SET A FRESH RACK AND THE RAKE IS ON THE WAY BACK FORWARD, THE RAKE BOARD TAKES A LITTLE HOP, NOT NICE AND SMOOTH AS THE REST OF MY MACHINES. DOESNT SEEM TO BE RUBBING OR CATCHING ON ANYTHING.
    JEFF
    TWIN OAKS LANES
    TOLEDO OHIO
    Re: THE RAKE
    Jeff, check your rake hook adjustment. I have seen them get mysteriously out of adjustment!! (big footed pinchasers) lol
    billman
    let me be myself
      Re: THE RAKE
      THANKS BILLMAN
      BUT I DID CHECK THERE ALSO. SEEMS TO BE JUST IN THE LOWER ARMS WITH THE BOARD. ANYTHING ELSE I SHOULD BE CHECKING?
      JEFF
        Re: THE RAKE
        Your rake cam could be a little out of time, check it out
        billman
        let me be myself
          Re: THE RAKE
          Jeff:
          Not nowing your serial #s, one thing that causes this problem, is a broken spring tube spring, or in the case of early model A's that had the double spring tubes, one of the tubes would bind owing to years of congealed oil and dirt, without enough spring pressure to overcome resistance. This results in a weird jump in rake as it's coming forward, as a result of spring tube being fully compressed at 270 setting pins.
          Off the wall, however have seen it often on double spring machines.
          Hope of some help, let us all know the results, as thats the only way we all can learn from these problems.
          Your friend.
          Roscoe
          rfm
            Re: THE RAKE
            Roscoe. It has been my experiance that when a rake spring breaks, you also get a jumpy movment in the deck. Please correct me if I am wrong!! ( been wrong before, won't go there!! lol)
            billman
            let me be myself
              Re: THE RAKE
              I would look at the 1/1 myself:
              A sloppy 1/1 key or shaft will cause the rake to nose-dive (around 4-5-6 row) setting new pins, and sweep OK on first ball.
              Try rocking the rake cam with power off on machine at 0. Compare play to next machine. Appreciable difference means the 1/1 may be saying it needs help.
              Kevin
                Re: THE RAKE
                billman
                typical that is the case with an A2 but with the rake set up of a model A machine. an A2 has one spring tube and the A has two spring tubes for the rake.
                alex
                Cloth: ShamWow!
                Machine: Johnny 5
                  Re: THE RAKE
                  Hey Jeff
                  The answers here are good but when is your rake hopping?
                  If it is when the rake is fully extended take a look at your rake hook and crank rod adjustment.
                  If it is during the sweeping motion try the rake cam timing.
                  Since you have model a's you might try adjusting it the way Brunswick says in the a-2 manual.
                  Put the machine in an EXACT 180 stop.
                  Release the clutch and mark or scribe a worm shaft nut.
                  Turn the clutch 2 revolutions backwards.(clockwise)
                  Loosen the 6 bolts holding the cam to the hub.
                  The cam follower should then fall into the low dwell of rake cam.
                  I had old model a's and this type of adjustment worked much easier.
                  Happy hunting.
                  Grambo
                    Re: THE RAKE
                    HEY THANKS GUYS
                    THIS BOWL TECH IS GREAT!
                    I'LL CHECK ON THOSE THINGS ALL HAVE SUGGESTED AND LET YOU KNOW HOW IT CAME OUT.
                    THANKS AGAIN FOR ALL THE HELP
                    JEFF
                    TWIN OAKS LANES
                    TOLEDO OHIO
                      Re: THE RAKE
                      Hey Shame!!! I have 28 Model As with just one spring tube!! I have seen the doubles and they make the pinsetter look like some sort of war machine!!
                      billman
                      let me be myself
                        Re: THE RAKE
                        You should see a J/B with one spring tube, and a 1/1 going south, rake tries to plant itself in the pindeck when she sets a new rack. When it starts to be visible, you know you have about 6 months to change the 1/1.
                        Never seen one with two tubes, where does the 10 pin side tube attatch to, bill??
                        Kevin
                          Re: THE RAKE
                          Hey Kevin
                          The old Otis green monsters had 2 rake tubes.
                          The deck lift shaft had a spring mount on each side of it.
                          The rake had tube mount bushings on each side also.
                          The little catwalk by the electrical box was smaller with a guard so as not to hit your feet while that tube was moving.
                          Bowl America has a center where 36 of the 48 lanes are serial number 1200"s
                          The old tube springs must have been weaker because we put a new spring in and removed one tube.
                          If the deck lift shaft wore out at the pivot or the rake broke at the tube mount you just move the tube to the other side.
                          Grambo
                            Re: THE RAKE
                            Hey Jeff,
                            One more thing you might check if everything else is O.K. is your rake shock. I had a couple of machines that as the rake would reach it's most forward position, the board would give a little hop upwards. There was no noise, as when the hook latch sticks, and no slop in the 1-1. Both machines had a new rake shock that seemed to have more internal pressure than the others, and that pressure would cause the "hop". Changed shocks, problem solved. Glitch
                              Re: THE RAKE
                              HEY GLITCH
                              MY OLD MACHINES HAVE NO RAKE SHOCK, JUST THE TWO SPRINGS UP FRONT AT THE TOP.
                              ANY THING ELSE?
                              I ALSO HAVE A NOTE IN MY BUDDIES QUESTION UNDER MOVING DECK SLAMMING. HE IS TALKING ABOUT MY MACHINE THERE.
                              JEFF KUHNLE
                              TWIN OAKS LANES
                              TOLEDO OHIO
