NPS link bind
  • NPS link bind
    Have one machine that intermittently will stay on second ball after NPS operation in 10th frame. Solenoid plunger moves freely, it seems that the loop end of the link is wedging between the top of the spring and the bottom of the standing pins latch (not wedging between the front of the spring and the back of the latch, seen that one before).
    Thinking about getting out a file, but just wanted to see if anyone else has a better idea on this:
    Thanx
    Kevin
    Re: NPS link bind
    ok clue me in what is NPS?
      Re: NPS link bind
      Larry:
      New pin solonoid, used in auto scoring for fouls and tenth frame.
      Roscoe
      rfm
        Re: NPS link bind
        Very GOOD Roscoe,I see you still remember what NPS is for (LOL,LOL)
        Kevin; try turning your link over or opening up the loop a little.
          Re: NPS link bind
          I'm not sure but it sounds like the same problem I was having and I had to drill a hole and put a stop in so the solinoid wouldn't come back as far resulting in less movement so it wouldn't go far enough to get into a bind.
          Drill
          Drill
          David Bolt
          Champaign, IL
          USBC Silver Coach
          IBPSIA BOD
          IBPSIA Advanced
          Technical Certified
          Pro Shops
            Re: NPS link bind
            Sorry about the really late post here (new guy), but I have the solution to this one. Remove the plunger from the NPS and grind 1/16 to 1/8 of an inch off of the back of the longest part of the plunger. You know, the part that goes into the coil. Our center had this problem too and it had something to do with a residual magnetic field in the coil/plunger holding it back. I ground them down and have had no more problems since. Maybe this will help others with this problem too..
            [ February 19, 2001: Message edited by: BrunsAce ]
            Sometimes it is best to use good advice from many individuals to achieve the ultimate result.
              Re: NPS link bind
              What BrunsAce said is true...I've never had this problem with an NSP but I've seen it many times with MOTOR START RELAYS, POWERLIFLT RELAYS etc...they become magniticed and even though the power is cut from them...they won't let go...on said relays, a piece of scotch tape solves the problem...but also with the relays, it's a simple contact and release motion...on a NPS there is so much friction happening that I doubt it would last for long...it could be a quick fix in the middle of a tournament though.
