Brandon
Having problems w/the time delay module on A2
I'm having a problem w/one of my machines shorting out my time delay board inside the box. It will reset my itself every 3 or 4 minutes, and then just short out. It won't reset period, not w/button or ET2001, after it shorts out. Does anyone know what this might be? Any help would be appreciated.
Brandon......Tags: None
Bowl-Tech Site Admin
- Nov 1997
- 5652
- Brunswick A, A2
- Brunswick Scoring Systems
- Kegel & A22
- All
- 1979
Re: Having problems w/the time delay module on A2
First place I would probably check is ball rack (bowlers) reset button cord. Most of the problems I have seen like that are caused by the wire getting pinched between the frame and the rake, sometimes at the top of the frame or the side. I have also seen those wires get pinched around the power lift as well. I would completely trace out the wires to the ball rack for any problems.
this is where I would probably start. keep us posted.
[This message has been edited by Mike Wilson (edited 09-25-2000).]Mike Wilson
Bowl-Tech Inc..
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
