Balls in Pinwheel
  • Balls in Pinwheel
    Here's a cool trick I just learned for getting a ball out of the pinwheel. Just pick up a pin and drop it in the other side of the pinwheel while the machine is running, (be sure to turn off power while getting a pin out) when the wheel carries the pin up it will push the ball out and let it go back up the rods. Call me an idiot but I've been digging them out by hand for the last 5 years, Im sure its safer also (bowlers still throw a ball after you turn the machine off, risking your fingers getting smashed
    Jerrid
    Re: Balls in Pinwheel
    You should readjust your lift rods so balls do go in there all the time. Pins go in there not bowling balls. Brunswick and Quality Parts make things that don't allow the ball to enter the pinwheel. The ones that i've seen used are the black plastic ones that bolt on the bottom guard. Look in the Quality Parts Catalog for them or the Brunswick Manual. Never once have I seen a ball in the pinwheel!
    ßA
      LOL, you haven't worked in this center, Every bowling center Ive worked in I've seen balls in the pinwheel. If you get one that yoyos and it's still in the lift rods chances are the next one is going in the pinwheel. And yes I do adjust lift rods to prevent that, I was merely explaining a trick that I thought was worthwhile posting. The A-2 is not supposed to have deck jams either but I bet you've seen a few of those.
      Jerrid
        Sorry A2 I just reread my post and did not mean it to sound so harsh I realize you are trying to help. I have bought a few of those rod caps from quality and they do work well, just expensive, about $40.00 last time I checked. I have had my hands smashed by an incoming ball or pin more times than I care to mention even after the machine has been turned off. So if there is a trick to save my fingers I am definately all ears.
        Thanks again
        Jerrid
          Good idea. I'll try that next time if I remember. Hopefully, there won't be a next time though Lucky for me the buttons on my 40 year old pinwheels aren't too sharp.
            I saw our night guy do that one time and i was really inpresses. ANYTHING to reduce your "exposure" is a plus. One time i turned off the machine, dropped the rake, and counted to about 20, then the second i put my foot on the floor CRASH... someone through at the rake. Bowlers are jerks! :-)
            What do we do with the bits left over?
