Quality lift track covers
  • Quality lift track covers
    I was just wondering if anyone besides me was having problems with Quality brown lift track covers. I recently had to replace a lift track cover on 2 different lifts. After replacing the cover I started having ball damage. The nicks were not deep but very numerous. Well, after checking all the usual places, I found the problem to be that the ball was hitting the motor mount at the rear of the lift. I have used these covers for years and never had any problem with them. What I did to fix the situation was to glue a piece of leather on the exposed piece of the motor mount. When I talked to my wholesaler he said that they had not had any complaints about the covers but had noticed they seemed to be thinner.
    Larry
    Re: Quality lift track covers
    Larry, Have not tried the brown ones, I usually get the red ones and have not had any problems with those. What you might do, since they are thinner, is to order the original leather covers, the ones we used on the glue on rubber tracks, that would bring your tracks back to specks. I did that on some grey ones I got years ago. Hope this will help you. PJ
      Larry,
      I use the brown ones and checked my C-tracks today after reading your post...I didn't see anything out of the ordinary. However, I haven't installed one for over 4 months. If things have changed in the last 4 months..I wouldn't know yet.
      Just my two cents worth...
      Steve
        I use tracks from Vantage,they are much thicker than normal reds/browns and hold up a LONG time!They look as if about 1/4 inch thick.I also see that they have a NEW style ROUND track fo the lifts,it looks like a urethane lftrod cover only solid,with hardware attached to it for installations.,no more metal edges from c-tracks to cause scratches,you get rid of the metal tracks and install these.Someday i'd like to try a set! F.Y.I.
          Anchorman:
          As usual, one gets a B.S. reply from a national supplier. It is a problem, just not one to be acknowledged from someone whom might be culpable. Have seen the exact same problem you encountered.
          Thats what so neat about this forum, you can run, but you can not hide.
          There is simply to much experience here to be BSd any more, and the old standby of, Have not heard of any problems, won't wash here.
          Many thanks to Mr. Mike Wilson.
          Roscoe.
          Roscoe
          rfm
            In the past Ive gotten "Theres nobody else having this problem, it must be something you are or arnt doing!"
            Dito thankyou Mike
            Ed
            Please buy MADE IN USA!
              Quote:]Originally posted by Ed Fox:
              In the past I've gotten "There's nobody else having this problem, it must be something you are or aren't doing!"[/QUOTE]
              I've heard that before as well. Last job I was working at, the company bought a batch of floppy disk duplicators. Gravity fed units, but the mechanisms were controlled pneumatically. Well, some of them started jamming. We call, and of course *they* never heard of this happening.
              Week or so later, we call again. Lo and behold, we were no longer the only ones having this problem. Seems the oil from the compressor was getting into the air lines and fouling up the mechanisms the air was feeding into...
                Hey Mok, sorry about slamming you in that other post! I was way out of line. Your a funny and very intelligent person.
                Ed
                  We had a terrible problem with quality tracks the balls would get to transition between tracks and just spin or stop.We tried alot of combinations and found that this worked best for us,
                  * Vantage 'C' Tracks_red kind
                  * V tire at bottom
                  * Go-cart tire at top
                  we have 47 lifts converted to this and so far no calls at all,
                  Good Luck
                  Peanut
                  Peanut
                    ditto masternut. i have 16 units with same setup. no problems.
                      Thanks for all the replies. I already have the V tire on the bottom and the Go Cart tire on the top. Sounds like the Vantage covers are the way to go.
                        I have seen the same problem with c-tracks
                        before and just to play it safe I also glue
                        carpet on the motor bracket.It is especially a problem if you very fast accelerators.I have found the thicker c-tracks such as vantage or headway to be the safest choice.
                          this problem with quality lift covers is obvious when you consider that when i started working at my present center, i had to change 4 pairs of lanes worth due to ball damage.......quality lacking???
