Pit carpet adhesive
  • Pit carpet adhesive
    Just curious what everyone is using for pit carpets and if I'm the ony one still using the $52.99 a gallon from the big B.
    It works great but I think most of the good adhesives would work on pit carpet.
    thanks
    Drill
    Drill
    David Bolt
    Champaign, IL
    USBC Silver Coach
    IBPSIA BOD
    IBPSIA Advanced
    Technical Certified
    Pro Shops
    Re: Pit carpet adhesive
    we use contact cement on ours the same stuff used to glue reg carpeting down in business's and the last few centers i worked at used the same thing
    james
    james
      I have used...Weldwood contact cement and have had no problems,about $17.00 a gallon plus i use it on ball wheel kickers etc too. If i cannot get that then i'll get Qualities contact cement.It's also a matter of preferance to what each person has best luck with along with...the $.The Weldwood has always worked great for me.
        I too use the weldwood contact cement ($17.50 + tax) Works well, but you do need to be sure you get enough on the "ears" or they will come loose sometimes.
        Kevin
          Weldwood worked best for me, price and adhesion not to mention the head rush!
          Ed
          Please buy MADE IN USA!
            Quote:]Originally posted by Ed Fox:
            Weldwood worked best for me, price and adhesion not to mention the head rush![/QUOTE]
            Just say No, Ed. (big evil grin)
              Same here...Weldwood contact cement...red label. They have come out with a "gel" version. I personally don't care for the gel style...but it does work just as well as the original.
              Jst my two cents worth...
              Steve
                Weldwood. Its even available from Graingers in a box of 4 1-gallon cans.
                Uh oh, too many mechanics agreeing on a topic...
                You know what that means... Brunswick will end up buying out Weldwood. [img]/content/btubb/images/%%GRAEMLIN_URL%%/shocked.gif[/img]
                Wookie
                  Another vote for Weldwood. No Smoking! WD-40 will clean it off your hands. No Smoking! Flammable!
                    Drill, you can also use Weldwood contact cement for about 15$ a gallon, works great.
                    Eric.
                    [This message has been edited by eric (edited 11-09-2000).]
                      Wookie,
                      And if Bruns bought Weldwood...they would then sell us their product anyway and claim the products were the same and charge us the higher of the two prices...LOL
                      Seve
                      Ball Returns Shorted Out?
                      Trip rocker arm
                      Lower ball cushion board
                      Backend motor plug
                      82/70 combi motors
