wormshafts..
  • wormshafts..
    It just came to me that...at another center i was at a wormshaft broke in half,it was a 2 piece style,anyone ever see those types?Broke at the threads.They we're factory A-2 with scotch yolks.Some WiErD stuff out there!..lol.
    Re: wormshafts..
    hey nighthawk,
    it sounds like you came across a repaired worm shaft in which they remove the bad splines and drill tap & die the new splines to the rest of the assembly i've had these work well and i've also had some that failed prematurely anytime i came across these while doing routine maintanence i always made a note to inspect these a little more often than the one piece shafts.
    hope this helps,
    brunsmechanic
    GOOD LUCK EVERYONE
