TDM
  • TDM
    I'm still having trouble with a few things in the TDM, first of all where can I purchase the capacitors listed in the tech. reference, I've tried everywhere on-line and can't find anything but uf's and I'm not smart enough to convert to mfd's? Is this more than likely my problem's? 3 machines work great in automatic but when placed in manual won't cycle unless plunger is activated, it won't even work with the reset button on the back of machine, no clicks or any responce at solinoid. Keep in mind everything works when in the automatic mode, on mine there is a button that bypasses the auto mode and puts it back to manual. The rake trigger switches are new because I just put them in. Is there a way to make the electronic triggering work when the machine is in the manual mode? I have the great belly up cpu's (Mendes) but don't care because I have enough new spare parts to get me by until I want a new scoring system.
    If I replace all the capacitors will this fix my problem? I have put all new cycle relays in them already and have a few spare TDM but they are in the same shape as the ones I have. After the Zot one I had crapped out after 3 months I gave that idea up, if anyone wants a non-working Zot TDM you can have it for the shipping. By the way, I only put them in manual because the High school P.E. classes want them that way and I can't get mad because it saves on my monitors.
    Thanks
    Drill
    [This message has been edited by Drillmn300 (edited 11-10-2000).]
    Drill
    David Bolt
    Champaign, IL
    USBC Silver Coach
    IBPSIA BOD
    IBPSIA Advanced
    Technical Certified
    Pro Shops
    Re: TDM
    have you tried the brunswick solid state tdm's? we have had problems with the zot version blowing resistors b/c of our scoring. (amf accuscore) also, what kind of electronic triggering do you have? if you run off the zot boxes try quality, brunswick, or murrey tdm's.
    sean
      Re: TDM
      Drill,
      First...uf's and mfd's are the same thing...microfarads.
      Second...Does this happen on all you lanes?
      Third...I doubt your capacitors are bad if it works in one mode and not the other. The problem is I don't know what type of triggering you have and how it is wired in. A little information and I can probably help you out.
      Steve
      [This message has been edited by JBEES (edited 11-11-2000).]
        Re: TDM
        Mendes scoring and triggering and it only does it on 3 lanes. I thought 1 was micro and the other wall milli.
        Drill
        [This message has been edited by Drillmn300 (edited 11-12-2000).]
        Drill
        David Bolt
        Champaign, IL
        USBC Silver Coach
        IBPSIA BOD
        IBPSIA Advanced
        Technical Certified
        Pro Shops
          Re: TDM
          Quote:]Originally posted by Drillmn300:
          I thought 1 was micro and the other was milli.[/QUOTE]
          It was when I try trying to learn to fix radios for the Marines...
            Re: TDM
            Drill,
            have you moved one of these three questionable TDM's to a machine that is not having this problem? If the problem stays with the TDM, then it could be the caps...but it could be a variety of other things also. There are diodes that can go bad, reed switch, resistors, ect. ect. But if the problem stays on the machine...the triggering is suspect.
            Just my two cents worth...
            Steve
              Re: TDM
              No, but that will be my next move though. I was hoping to buy the caps local and see if that did it but I think moving it first would be the best solution to narrowing the problem.
              Thanks
              Drill
              Drill
              David Bolt
              Champaign, IL
              USBC Silver Coach
              IBPSIA BOD
              IBPSIA Advanced
              Technical Certified
              Pro Shops
                Re: TDM
                Well, everything is back to normal, I traded in my 3 old ones to a guy in St. Louis for $21.00 apiece for ones that were rebuilt and they all work now.
                Thanks for all the help.
                Drill
                Drill
                David Bolt
                Champaign, IL
                USBC Silver Coach
                IBPSIA BOD
                IBPSIA Advanced
                Technical Certified
                Pro Shops
                Ball Returns Shorted Out?
                Trip rocker arm
                Lower ball cushion board
                Backend motor plug
                82/70 combi motors
