SUBMARINE MAYBE
SUBMARINE MAYBE
OK GUYS HOPE YOU CAN HELP. i HAVE A LANE GOT HIT LAST NIGHT OTHER MECH. PUT ON NEW PARTS FOR RACK. CAME IN THIS MORNING AND FIRST THING THAT HAPPENED WAS RAKE STAYED BEHIND THE DECK ON SECOND BALL SEATING NEW PINS. BENT RAKE CRANK ARM BADD STRIGHTENED OUT HAPPENED THREE MORE TIMES NOT IN A ROW. PUT ON NEW RAKE CRANK AFTER THAT MADE ADJUSTMENTS. LATER ABOUT 30 FRAMES HAPPENED AGAIN. COULD THIS BE IN THE 4TO1 OR SOMETHINGELSE. GOING TO WORK ON IT AFTER LEAGUE PINCHASER CLEARING PINS BY HAND. HE LOVES ME NOW.Tags: None
Re: SUBMARINE MAYBE
Craig:
Most bent crank links happen when the shotgun, or Rake Trip Assembly, comes unlatched when sweeping. The angle iron on top seven side is supposed to prevent this, IE, the rake dropping behind the tailplank at 180. With the shotgun latched, run the rake back to 180, at that point the angle iron should just be touching the rabbit ear while the bottom of angle is nestled snug against the machine frame. If a straight model A, with no shotgun, please respond as other problems exist.
Roscoerfm
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
