power savings
  • power savings
    I got word that our electric bill is going to jump (50%) higher. I would like to know if it's possible to connect another 24v relay to the pinsetter circuit, (to control the overhead scoring monitors power) will cause an overload to the 24v pinsetter circuit.
    Re: power savings
    Larry...if you use a small relay supplied by Grainger or similar, it will draw less than 250 milliamps or 1/4 of an amp. You have plenty of spare power left in the transformer to supply this. Also, may I suggest trying a device from Bowl-Tronics. A motor shutdown kit. This topic has been discussed before and came back with mixed reviews. I don't wish to re-debate it here, but if you are interested in saving energy dollars, this is a sure fire way of doing it. I have a few already installed and they work fantastic.
    Just my two cents worth...
    Steve
      Re: power savings
      YOU MIGHT WANT TO THINK ABOUT HOW YOUR POWER IS BILLED TO YOU.
      DEMAND OR USAGE.
      SOME THINGS ARE BETTER JUST TO BE LEFT ON OR RUNNING. WEIGH IT OUT, WAIR AND TEAR OR ELECTRIC BILL?
      JEFF KUHNLE
      TWIN OAKS LANES
      TOLEDO OHIO
        Re: power savings
        Don't leave your HVAC equipment out of the equation. That is one of your biggest costs in keeping a building running. If you don't already have them some sort of energy saving thermostats, make sure the equipment is in good shape, clean, filters changed.
        just some other ideas
        Mike
        Mike Wilson
        Bowl-Tech Inc..
          Re: power savings
          I would agree with Mike on this one,when you look at all of the things that use electricity in your center overhead monitors are not the types of electrical loads that use alot of power.I would look at hvac first
          and lighting before I started looking at monitors.
            Re: power savings
            Larry,
            I see you are in California. AMF recently purchased a center in California that had NO AC in it. The weather was too mild for the original owner to consider it from what I heard. Depending on your climate, AC may not be as big of a deal as a center in Texas or maybe Phoenix...
            We are currently looking into a company that installs some kind of a sine wave converter onto the incoming electrical lines and they guarantee a savings on your energy bill. Don't have the specifics right at the moment, but I will post some info on this later. If it works...could cut electric bills by 25% I was told.
            Steve
              Re: power savings
              HEY JBEES
              YES PLEASE BE SURE TO FILL US IN ON THAT SINEWAVE PRODUCT, LORD KNOWS I WOULD LIKE TO TAKE A FEW HUNDRED BUCKS OFF MY BILL!
              JEFF KUHNLE
              TWIN OAKS LANES
              TOLEDO OHIO
                Re: power savings
                thanks for info guys. Found out this morning electric rates will jump 2-3 times the rate is now.
                keep info coming
                thanks
                  Re: power savings
                  Quote:]Originally posted by Larry:
                  thanks for info guys. Found out this morning electric rates will jump 2-3 times the rate is now.[/QUOTE]
                  Ah, you must be next in line for deregulation... now you get to feel our pain.
                  Think it's bad now? Wait until summer hits.
                    Re: power savings
                    Hello all....as Mike mentioned about HVAC usage, it is one of the most energy consuming devices in a bowling center. At my center, we use a Honeywell time clock system, which basically does everything from turning on lights to turning off water heaters when not needed. Anyway, what I recently did, was restructured the on/off times of all of my A/C units to coordinate with league bowling times, and occupancy times in specific rooms of the center. By doing this, I was able to save approximately 80 hours of unnecessary usage per week. Also, another thing that will help, but may cost you initially, is to install motion-sensing light switches in your least occupied rooms, like store rooms...because how many people will turn on a light, but not turn it off....just some things you might want to consider to conserve energy.
                    Ball Returns Shorted Out?
                    Trip rocker arm
                    Lower ball cushion board
                    Backend motor plug
                    82/70 combi motors
