Knurl pins
  • Knurl pins
    Hey Guy's
    Whats Up? Just wondering If anyone has ever made a tool or discovered a easier way to remove and Install a knurlpin where the lower scissor cable connects to the toggle lever.
    Man those puppies are always hard to get In,The knurl pins fit so tight.And yes,of course the cable Is disconnected!!
    The Master
    Re: Knurl pins
    I use a c-clamp, a piece of tubing or a socket to accept the pin and an x-washer pin to press it out. Takes some juggling but it works. Guess you could have the parts welded together to make it easier. I have seen a chain breaker modified to do the job also, they run about $30 but if you have very many to do maybe worth it to have a tool to make it easy.
      Re: Knurl pins
      Thats what I did, I welded the end of a c-clamp so It did not swivel & I use a socket and an old pin.
      Just figured someone might have figured an easier way, Chain breaker huh!!
      Thanks, the Master
