Vantage lift tracks
  • Vantage lift tracks
    Sorry guys!!! Just found out my distributor was out of Vantage lift tracks and subbed some black ones and attached the Vantage hardware to them!!
    Red faced......billman
    [This message has been edited by billman (edited 12-12-2000).]
    let me be myself
    Re: Vantage lift tracks
    watch for the 'v' tires. I beleive the v' tires put too much pressure on balls causing jams. This added pressure may cause tracks to pull out. try the tracks with the reg tires. I also saw the new quality tire, looks good, no webbing like previous version. Although time will tell.
      Are those the new round vantage urethane tracks? I saw those types in their catalog and they look good since you dont use the metal c-track anymore just install these and no scratches from the lifts.Anyone try those new round styles??
