modular rake shaft
  • modular rake shaft
    <MARQUEE>*Just a bit of info*</MARQUEE>
    I just recieved a new style modular rake arm, When doing a swap out I found that the spacer they send with the assembly is too short. They use a thicker steel on the brackets that the sweep hook block bracket mounts to (which makes it 1/8" wider) so if you use the spacer they send with it, it will bind up. I had to use a 10-386097 spacer in place of 12-250011-11 to take care of the problem.
    Jerrid
    Re: modular rake shaft
    Jerrid...who's rake arm are you speaking about?
    Steve
      *Cough- Quality -Cough*
