[This message has been edited by robert kallush (edited 01-25-2001).]
deck allens
Tech of the Year 2005,2007
- May 2000
- 16570
- A/A-2, GSX, Sherman, AMF
- Qubica/AMF/Brunswick
- Kegel/AMF/Brunswick
- HPL/SPL, ArmorPlate/Anvil
- 1977
Re: deck allens
I would assume you mean stripped. If they were broke, they would just fall out. If the heads are stripped, use a 1/4 inch drill bit and drill the head off. This will remove only the countersunk part of the bolt and not hurt the deck.
SteveTSM & TSM Training Development
Tech of the Year 2004,2008
- Jun 1999
- 4204
- A- 2 / 8270
- Qubica / Frameworx
- Phonix-S / Kustodian
- Prolane / HPL / SPL
- 1983
Re: deck allens
I use a left handed drill bit...it bites into bolt shank and backs it right out.
Hope this helps,
PeanutPeanut
Re: deck allens
On allens that the heads get stripped i usually use my trusty ball pean hammer and hit the head of the allen until it closes up SOME then,tap my allen key into the allen bolt and unscrew 'em.Has always worked great on the lower ball wheel guide roller allens!Backs them baby's right out.Of course drilling is also another option and very good too if ya got good sharp bits..not like here, most ca'nt go into butter...LOL.
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
