Cam Follower Shaft
  • Cam Follower Shaft
    About once every 2-3 months, on lane #5, the Cam Follower Shaft will break. I have checked almost everything I can think of, but no luck. I have gone through 4 this season. Any thoughts off hand? Thanks in advance for the help!!
    Mike Tarrant
    Hobart Lanes
    Hobart, Indiana
    Mike Tarrant
    Hobart Lanes
    Hobart, Indiana
    Re: Cam Follower Shaft
    Which cam follower shaft?
    If you are talking about the moving deck cam follower shaft and the bolt is what is breaking, check the tension of the moving deck torsion spring. If it is too tight, excess pressure will be applied to the shaft and the bolt. However, I have never heard of the shaft itself breaking. Just the bolt.
      There are alot of cam follower shafts on these machines.
      I'll go with JBEES, and assume you are talking about the bolt in the moving deck cam follower. Check all that JBEES has mentioned, plus make sure you use the hardend stud, or a grade 8 bolt. Anyhting less just won't last long. That thing gets alot of stress put on it.
      If you are getting alot of DJ's on this machine, fix that first. (of course you probably knew that)
      Hope this helps..
      Hope this is the right shaft too
      Adam D.
        I have seen [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img] the hole in the plate wear out really bad! I also installed the "Q" locking collars and that seemed to get rid of some of the wiggle.
        [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] ED
        Please buy MADE IN USA!
          M Tarrent.
          Mr. Fox is on to this one. If a bolt once breaks, I replace the shaft with a new one, using the set screw # 12-400300 (double drive assembly), old shafts will have a groove worn in them where they sit in the mtg. plate.
          Also use a locking collar (on all MD. shafts), even those whom have never broken a bolt.
          If it breaks the set screw, only fix is to either replace the plate or weld a support collar on the old plate.
          I use Pt.# 11-102220=000. bored to 13/16, and welded to plate with the set screw hole in it facing the front, provides a permanent fix ,as the set screw prevents any movement.
          Hope of some help.
          Roscoe.
          rfm
            Sorry I didn't specify which shaft. It is the Moving Deck Cam Follower Shaft. The shaft itself is breaking, not the stud. I will only put a shaft in that has the stud. The last time it broke, it bent the bottom of the mounting plate, I think i got that straightened out pretty well though. Thanks again for the help!!
            Mike Tarrant
            Hobart Lanes
            Hobart, Indiana
            Mike Tarrant
            Hobart Lanes
            Hobart, Indiana
              JBEES:
              Well I guess there is a first time for everything. I cannot conceive of any possible way to break a 13/16 in OD. relatively soft shaft, with no more leverage exposure than 1/16 in. max. Also cannot imagine anything breaking it without ripping all three legs from the one to one cover. Have seen plenty of the cable shafts break, they are very brittle, and thus don't take kindly to shock loads. Certainly would like to hear more on this subject.
              Roscoe.
              rfm
                Hey Roscoe
                I would also like to know how it is breaking this shaft and not a 5/16th bolt.
                But I will add that once the 1-1 plate gets bent the hole seems to get oblonged even though you straighten the plate causing the "bitch" bolt to still break.
                One thing no one has brought up that can cause the cam follower shaft bolt(bitch bolt)
                and also the moving deck control shaft that goes through the frame to break.
                IS the machine BLACKING OUT!
                If the machine does not stop with a deck jam all kind of things can be broken.
                I used to check it by taking the allen wrench that fits the gearbox drain plug and use it as a pry bar to force down the blackout tube springs and open the switch.
                The blackout switch could be stuck,or the motor contactor contact points could be sticking not allowing the machine to turn off.
                OR you could have what happened at my center when Brunswick wired up the auto-scorers.
                When they hooked up the wires in the electrical box they wired the mechanics on/off switch in parallel to the control desk switch AND in parallel to the blackout switch!!
                Graham
                  I agree with installing the collars and grade 8 studs and would also add that once the 1-1 plate has been bent a couple of times it best to replace it.Even when it looks like you have got it straight it usually is not perfectly straight and this adds to the pressure on the shaft which contributes to further failures.
                    Mike,
                    It would be very interesting to know what would break that shaft. I know wierd stuff can happen in these machines from time to time, and every time extreme pressure is applied to the area we are speaking of, the result has been a broken 1:1 casing in my experience. Something way out of the ordinary must be happening with that lane. If you ever figure out what it is, please let us know...just another for the wierd book...
                    [ March 17, 2001: Message edited by: JBEES ]
                      Quote:]Mr. Fox is on to this one.[/QUOTE]
                      Thanks Roscoe, that dosn't happen very often!!! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                      Ed
                        You said it, not me.
                        :p
                          G.M.
                          Were you referring to the shaft breaking?
                          Roscoe.
                          rfm
                            LIKE THE OTHERS HAVE MENTIONED ABOUT THE BOLT ON THE CAM FOLLOWER SHAFT, MAKE SURE IT THE THE GOOD HARDENED ONE AND ALSO GET THE COLLARS FOR THE SHAFT AND TIGHTEN THEM ON FOR THE EXTRA PROTECTION. YOU CAN GET 2 PIECE COLLARS SO YOU DONT HAVE TO TAKE EVERYTHING APRT TO PUT THEM ON.
                            JEFF KUHNLE
                            TWIN OAKS LANES
                            TOLEDO OHIO
                              Sorry it has been a while since I have posted anything...I have been in the process of moving to a different city. Here is an update on the MD Cam Follower Shaft problem. I just got a 1:1 mounting plate that I ordered. Haven't had time to put it in, but I plan on doing it within the next couple of days. I'll keep you guys updated as much as possible on the problem. Later!!!
                              Mike Tarrant
                              Hobart Lanes
                              Hobart, Indiana
                              Mike Tarrant
                              Hobart Lanes
                              Hobart, Indiana
