Power lift motor
  • Power lift motor
    I was looking thru the Grainger catalog for a motor that is compatible with the bruns motor. Has anyone found a motor from Grainger that will work, if so could I get a Grainger number from someone? PJ
    Re: Power lift motor
    HELLO PJ,
    I TRIED GETTING A POWER LIFT MOTOR FROM GRAINGER ONCE, EVEN WENT TO A MOTOR REPAIR SHOP. AND THEY COULD NOT DO IT. THE REASON IS BRUNSWICK HAS THEM SPECIAL MADE WITH A LARGER SHAFT I THINK IT WAS 1/2 OR 5/8 INCH SHAFT AT A BULK RATE. SO ORDERING THROUGH SOMEONE ELSE, THEY WOULD HAVE TO SPECIAL ORDER ALSO AND IT WOULD COST YOU MORE THAN ORDERING IT HROUGH BRUNSWICK. SO YOUR BEST BET IS BRUNSWICK. BUT YOU CAN GET YOUR PINSETTER MOTORS THROUGH GRAINGERS.
    GOOD LUCK
      I have the part # for Grainger at work. I will post it here tommorow after work.
        The Grainger motor I use is #6XH94
