sheet metal deck shoot supports
  • sheet metal deck shoot supports
    Back in the 60s and 70s when a deck shoot split we had preformed sheet metal supports that were cut to fit around the shoot and you bolted it together. It held the shoot in proper form and we made the shoot last almost forever. Have any of you used this method and if so, where can you get the patterns to make some? Thanks.
    Howard
    Re: sheet metal deck shoot supports
    Mulboro,mfg had these in there catologe for a while they use to make and sell them....check them out and see if thet still do or have the pattern you need.They are listed in bowltech yellow pages.
    later
    peanut
    Peanut
      Hey Howard
      I used to save my old long accelerator belts.
      I would cut them up into small pieces depending on the crack of the chute.
      I would put some epoxy in the crack and then use epoxy to glue on a piece of the belt to the back side of the deck chute.
      Graham
