pro anvilane decks
  • pro anvilane decks
    anyone else with OOR problems on pro anvilane decks?????
    mine are two years out and still a problem
    full of basecoat right now, but looking for an alternative...
    pins are fine, decks are clean, etc... does anyone know if the engineers for pro anvilane, frame-maybe-worx, and pinball wizard are still alive? please forward address!!!!
    Re: pro anvilane decks
    One solution (literally) that we have found is to mix powdered Tide in water, put in a spray bottle, and spray around the pin spots from the 2-3 spots back, making a lattice pattern around the spots.
    The key (and this also works on wood decks) is to make the Tide solution as thick as will go through a spray bottle. When it dries, pins will tend to fall over (or at least tip) instead of slide. Great enhancement for bowler's scores, too.
    The long term cost of inaction is greater than the percieved short term convenience.
