lift rod cleaning
  • lift rod cleaning
    What is the best way to get the lift rods spotless?!?
    Brandon Adams
    Iperial and Twin Oaks Lanes
    Toledo, Ohio
    Re: lift rod cleaning
    Put new covers on! [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
    Just kidding..................use your favorite degreaser...hopefully mine, and scrub till your arm cant take it any more.
    Please buy MADE IN USA!
      We use liquid tide mixed in water, nothing fancy ... and works as well as anything else. You do need a bunch of elbow grease too, but Ed already said that:
      Kevin
        we use the urethane cover from quality, the maroon ones(it the same material as the power lift "c" tracks) and to get them spotless only takes a little lane cleaner (mixed about 10 to 1) spray it on a rag. wipe the lift rods with damp rag, then wipe dry with clean rag....work like a champ.
        alex
        Cloth: ShamWow!
        Machine: Johnny 5
          I agree with shamefowjze. those red covers were the best, plus it was easy to see where the are dirty.
          I cleaned them a few times every night with a all porpose cleaner. worked wonders, and by cleanng them a few times in a night they stayed clean and naver gave any hassles
            use straight poly-chem st-21 or PA cv-98 or simular strong cleaner. spray them down let it soak in, about 5 minutes then respray and wipe them off if they are real dirty it will take a couple of times. after cleaning about a billion lift rods i've found this works best for me.
            bruce
              A2Pinchaser, i've used a rag or a brillo pad w/water and cleaned rod covers with a little
              elbow. It works good and you save money and
              rod cover life.
              mr.roboto
                If you are cleaning the gum rubber ones, or even the heavy duty ones from "B" (red), be careful as some cleaning agents actually deteriorate the material. The covers will stretch, and/or tear. [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img]
                I like to use the "Non Toxic Machine Cleaner" from DBA. It gets them really clean, however if you let it set too long on them, you run into the affore mentioned problem. Lane cleaner works well too, but requires more scrubbing. [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img]
                Ball Returns Shorted Out?
                Trip rocker arm
                Lower ball cushion board
                Backend motor plug
                82/70 combi motors
