Good old #10 starts up like it should and runs awhile and then blacks out. By simply switching the circuit breaker on the pinsetter electric control box to off and then back to on, it starts back up again and runs for awhile. Then the same thing will happen again. I'll bet this is a simple thing for you experienced mechanics, but it is something I need help with. Thanks again for reading my post and helping me.
pinsetter blacks out
Re: pinsetter blacks out
You didn't say whether the breaker was ON or TRIPPED when this happens, the following ass-u-mes that the breaker is ON:
Do these machines have the electrical deck jam interlocks on them (machine would have an extra relay inside electrical box, in a clear plastic case, and most likely the steel bar that looks somewhat like a pin gate strap coming up near the clutch lever to lock out the clutch in the event of a deck jam)??
If so, what's probably happening is a weak spring in the deck jam tube is causing the machine to flicker when the deck shifts back, which the relay interprets as a deck jam, and the breaker must be turned off to reset the relay. Tip off to this would be that the machine is at about 185 degrees, on second ball with rake just starting to come forward after sweeping when it blacks out.
Another possibility is that the breaker is just getting weak after years of service, would also be smart to check the condition of the wiring where it runs over the rabbit ears, and also near any other moving parts, but the stuff in this paragraph would cause the breaker to trip:
Kevin
Agree with Kevin
Proberly have the deck jam kits installed on your machines,the deck and turret jam switches are wired parellel and if either on of them opens up it energizes the jam relay.Then the breaker has to be opened up and closed again for the pinsetter to come on.Check the turret Jam Switch and the deck jam switch to see if they are adjusted correctly and that they are mounted tightly.
Hope this helps,
PeanutPeanut
Although I have never had the jam kit they are talking about but yes I have heard with this kit you need to cycle the breaker to re- start the machine for safety reasons.
If you do not have this check the breaker with a meter.
Put one lead on one of the bottom lugs of the breaker and the other lead on ground.
If you read 115,or 208 then the breaker is good and you have this kit, if it reads zero then you have a weak breaker that needs to be replaced.
I would also check the electrical box cover, if it is loose it can vibrate and trip the breaker, also can get false trips if breaker or wires are not secure.
hope this helps.
Graham
