Failure to index
  • Failure to index
    I have a machine that fails to index after the 7 pin drops off the snubber into the turret.
    I have changed the wires as it was suspected that the wires were worn and causing a drag on the pin. They are installed correctly in the wire guides, top and bottom.
    Trip lever works correctly on all other pins and this only occurs occasionaly, but it is bothersome at best.
    HELP!!!
    Re: Failure to index
    Hey Gene, the first thing I would check is the clearance between the halo and the 5 pin or center chute.
    Drill
    Drill
    David Bolt
    Champaign, IL
    USBC Silver Coach
    IBPSIA BOD
    IBPSIA Advanced
    Technical Certified
    Pro Shops
      Gene:
      I have had a few machines that have done this in the past ... Check the bushings in the trip pedal and the shaft the pedal rides on. Most likely the bushings are worn, and it will index fine on the other positions, but the 1/7/10 it'll sit there and look at you every once in a while:
      Kevin
        Gene:
        1/7/10s, are the hardest to index of all pins owing to the fact the pins impact is slowed by the inside of the wire, combined with the reverse slant of the wire. One thing common to four piece wires is the kickout at the bottom, they must be spread out so as not to impede the pins striking the trip lever. Indeed many times one has to take two large bars and spread them to allow sufficent impact on the trip lever. One also has to consider loose linkage in indexing mech. when this problem is encountered.
        Good luck.
        Roscoe
        rfm
          Don't forget your snubber adjustment. I had that happen recently on the 10 pin. The subber needed to be a little closer, but without causing a failed to index on the 2,3,4,6,8,9 pins.
            I want to thank all of you. I disassembled the trip lever shaft and found that both bushing were cracked and or scored rather badly, but, wouldn't you know, not a bushing on the premises. I ordered 2 and will put this thing back together when I receive them. I will keep you all apprised.
              KL Kevin;
              Right Answer!
              You are the man!!
              Afer replacing both bushings on the trip lever and hand working the fit until it was very snug but loose enought to rotate on the shaft, there has not been a stop.
              Thank you very much.
              Gene [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                Gene:
                Glad I could help, but the credit goes to PJ at Zot, he taught me this one when he was the tech at BowlMaster.
                My machines are in the 20,000's so wear in that area is becoming a factor. If one machine is starting to do it, well .... you know [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                I keep at least one set on hand, since it's a brunswick-only bushing, and not always easy to get in a hurry. I've had to do 2 so far out of 16, and I have one that I have to go after once Labor day hits, and things slow down here:
                Now you have two more oil points to add to your PM schedule, if you weren't hitting them already, as changing those bushings is a PITA [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                Kevin
