Jackscrews
  • Jackscrews
    Installing HPL overlays, [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img] need part # for longer jackscrews. Some of mine are maxed out now.
    Thanks, billman
    let me be myself
    Re: Jackscrews
    We had to do the same thing. What we used was Lawson # 56026 7/16-14x2. It was long enough to lift the pinsetters.
