All of the 1st and 2nd ball light plastic housings are either busted or melted. Some have a tin cup with a hole in the bottom glued on. The light bulb and the light assembly fit into the hole in the bottom of the cup. Does anyone know where these cups can be purchased from? Someone told me that they were the cups that were used in the older pop and ash tray racks that hooked on the back of the bowler seating up front. Thanks for reading.
1st & 2nd ball light tin cups
