Curious to know if any other techs are having issues with the collapsible rake crank rods...I have had 2 break the internal weld between the spring and the rod(toward the 4:1 end), and subsequently become wrapped around the main brace next to the cable pulleys assembly....Craig had to burn the first one off with a torch....I had enough clearance to cut the second one loose with a sawzall.....what a bitch....LOL
any explanations or 411?
Mike
[img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
I have the ZOT Collapsible Rake sweep links installed on 32 lanes about 4 years in service with no troubles. I did receive several collapsible links from another competitor, believe it was Quality, so we gave them a try and less than a year they failed in the same place towards the 4 to 1 crank arm end. Needless to say we replaced them with ZOT .
I've tried a few from Zot, Quality, Brunswick and Vantage. Had a problem with the bolt inside the tube coming loose and having the entire thing fall apart. I started to take the rest apart and locktite the bolt in place. Found the ones from Vantage come that way...didn't need to do those. No other problems thus far...
Any chance of getting the part #'s for Zot and Vantage on this??? Would like to try one of each and I don't think my books list them or I'd have seen it before....the help is appreciated guys.
Mike
[img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img]
