Thanks for all your input. Went in yesterday on my day of and changed the ball wheel. What a job (3 hrs). Had an old wheel that had been welded years ago, cleaned up as best I could, a little out of round but working. This is not Jap machine, A-2 field converted. It broke right in the original joint. Should be fixable. PJ
Pin wheel replaced
