i went to pull a 1 to 1 today and could not for the life of me get the drain plug out.....it was stripped. i was wondering if any of you guys had run across anything like this and if you had how in the hell did you get that thing out [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] i ended up drilling a small hole in it and draining the oil that way(very slow) hoping that maybe i could use an ez-out but no luck. that baby is in there. there's not enough thread showing to get a pair of vise grips or anything on there.
by the way i used roscoe's 1 to 1 removal and it took no time at all. thanks roscoe.
alex
Cloth: ShamWow!
Machine: Johnny 5
Obviously the best thing is to get the plug out - but the oil can also be drained thru the lowest 4:1 socket head cap screw. I think it's the 3rd from the rear along the bottom. The oil will drain, but slow, and you won't have a hole to patch.
I've removed numerous plugs by sticking the long
end of an allen wrench in the stripped plug, put
a couple spot welds on, & put wrench on allen.
They come right out.
If you have several to do, I used to get about 8
plugs out of 1 allan wrench. Once removed I took
a die grinder & cut off allan wrench at the plug.
Good Luck
You need to be VERY careful with this because if you put too much pressure on that plug, you might break the gear box housing. My old instructor at pinsetter school says to spray some liquid wrench, or WD 40 and let it sit for a while. If you can do it from the inside, with the 1 to 1 still out, would be better. If that doesn't work, you have no choice and drill a hole like you did but make it big enough where you would be able to thread and install another drain plug.
By the way, where is it stripped? The threads, or where the wrench goes. What I described would be for the threads being stripped. Sorry I should have looked before I leaped.
it's stripped out where the wrench goes, the threads seem ok but i haven't been able to look at them. but no obvious signs of crossthreading. i figured i'd have to weld the wrench on there thanks for the input guys.
alex
Cloth: ShamWow!
Machine: Johnny 5
I had the same problem once. Seems some bonehead cross threaded the drain plug. I drilled the drain plug out with a 1/2" drill and used the biggest easy out I could find. Used a crescent wrench and a breaker bar. It came out. I replaced it with a hex head plug, and made sure I sealed it with some silicone. never had a leak.
alex.. the idea with taking screw out of 4 to 1 cover from gary would be your best way for you it does take a little longer .. but after working with in the past i am not sure you are strong enough to turn the allen wrench if you welded it on the plug .. just messing with you .. i hope you are freezing your butt off...
