Deck Now Wont Move Up Or Down
  • Deck Now Wont Move Up Or Down
    Anyone have any suggestions to the deck not moving up or down..??
    Re: Deck Now Wont Move Up Or Down
    Is anything else moving? 4 to 1 ? If nothing else is moving, except maybe the clutch, I might think a broken worm shaft, and they can be a lot of fun getting out of the gearbox. Could be, if you have scotch yokes, a broken jack bolt on the end of the plate and the 2 to 1 is not lifting deck up enough to come off the holding hook. Neeed a little more info on this kind of problem. Whare is the deck right now?
    Marty
    [ December 31, 2001: Message edited by: marty murphy ]
      if you cannot move the deck up or down check the spring guide tube. spring may be broken and jamming the tube. try moving the rake, if it moves then guide tube may not be the answer. GOOD LUCK
        Thank you this one is resolved..
          What was the problem? Interested in hearing what is was.
          Marty
            If you toggle the deck holding hook at the "wrong" time while the machine is cycling, the deck wont move, but the 4/1 and so forth will be functioning.
            Hard work and determination is the answer to all problems.
