Scissors
  • Scissors
    On one of my pinsetters, 2 of my scissor units are real sloppy (2 and 4). The rest of them are ok when opened, little play. But the two units when opened I can move the left scissor arm about 6 inches toward the right one. Have changed units and still the same. PJ
    Everyone have Happy New Year.
    Re: Scissors
    PJ:
    Site down the actuator bar and check it for a bow, if its' a square tube model. If its' a flat bar model, check the big bushing in the bar where each sissor is attached.
    Roscoe.
    rfm
