Pin In Lift Rods
  • Pin In Lift Rods
    Recently I have had two occurences of a pin getting caught in the lift rods (A-2 machines. This makes the ball get a gouge all around the ball. My mechanic says there is nothing we can do, that it just happens once in a while....
    Any thoughts...
    Re: Pin In Lift Rods
    It's going to happen once in awhile but there are things you can do. Zot makes a lift rod clamp that allows the pin to go through and I believe you can also use a bungee cord setup. I use the Zot lift rod clamp and might get one or two pins caught in a year but it doesn't hurt the ball.
    good luck
    Drill
    Drill
    David Bolt
    Champaign, IL
    USBC Silver Coach
    IBPSIA BOD
    IBPSIA Advanced
    Technical Certified
    Pro Shops
