At least 5 lanes have slow dropping rakes i mean, they drop okay but seems to be held up from dropping fast enough.When the machine starts to cycle then it goes all they way down,first or second ball.Adjusted cushion linkages so as they do not interfere with holding the rake dropping back.
Could it be the rake shocks,they seem to be an old style,flat on the shock top and not like the ones you see in the book.Jap A-2 units.We get too many calls for deadwood due to the rakes dropping tooo slowly and i hate stupid calls!Cushion linkages are LOOSE but not too much so it has slop in them(i checked them and adjusted for more slop,did'nt help to get the rakes to drop faster).
One lane i see the rake drops and stays about 4"above the lane surface when the ball triggers the cushion,then when machine triggers it drops all they way down where it should be in the first place.I am used to rakes that drop fully and smoothly,not ones that seems to be held up by something.Shotguns are good with proper gaps etc.
Just bad,old,tired shocks or cushion shocks?Just trying to get things in order around here.
Get rid of stupid stops/calls and life can be a bit easier.
