Torsion Latch
  • Torsion Latch
    I had a lane that would not index after 5. I looked & looked, I found that tha torsion latch was hard to move. The torsion latch was going to far in on the time delay gear & I also found that the bumper was worn out. So I went to change it, But we didn't have one. So I came up with an idea to use a follower link roller & spacer. It work's great, for an emergency fix.
    Re: Torsion Latch
    Nice Job,
    that machine ran quite well I might add.
    Jerrid
