Replacement pin wheels
  • Replacement pin wheels
    24 pinsetters, 8 with A pinwheels, 15 with A-2 pinwheels, 1 A-2 pinwheel replaced with a Quality Bowl about 6 years ago. Now it's time to replace another A-2. The Quality Bowl one looks like it will last forever. Anybody got good or bad things to say about other new ones?
    Re: Replacement pin wheels
    Quote:]Originally posted by mr.badwrench:
    24 pinsetters, 8 with A pinwheels, 15 with A-2 pinwheels, 1 A-2 pinwheel replaced with a Quality Bowl about 6 years ago. Now it's time to replace another A-2. The Quality Bowl one looks like it will last forever. Anybody got good or bad things to say about other new ones?[/QUOTE]
    [ January 31, 2002: Message edited by: viper ]
      I have had no problem with the quality pin wheels at the former japantown bowl in s.f. ca and i put 40 of them in and they were in 5 years before it closed.brunswicks modular type are noisy when pinwheel is moving.good luck.
        If you like to watch your pinwheel shake, rattle and roll...buy the modular pinwheel from Brunswick. If you want a pinwheel that will last a lifetime...buy the one from Quality. Now, if you want to save a little money and get the same pinwheel as the Quality one...buy it from Murrey. I have had great luck with this style pinwheel. It is so smooth running that if you are more than 6 lanes away from it, you can't even tell it is turning. I don't know how many times I'm walking the back ailse during leagues and start heading for that lane because I think it might have a 180 because the pinwheel is not turning.
        Good pinwheel.
