Ball Wheel
  • Ball Wheel
    Had an interesting problem today, the ball wheel came apart at the seam. There is a small commpresion clamp on the inside of the seem and the weld broke free to a 2" gap in my wheel. I forunately had an extra and it was a half a days work just to change one out as I have never done or seen this happen before. Has anyone else had this happen or is there some way to do a stress test on it? It looks to be pretty easy to weld back but it was a first for me. All the upper and lower ball wheel guide rollers are fine or at least they were before this happened and the lift rods are adjusted to the tee. I posted a picture of the inside of the ball wheel in the gallery if anyone is interested.
    Let me know if you have a clue as to why this might have happened, even though they are converted A2's built in 1961.
    thanks
    Drill
    [ January 31, 2002: Message edited by: Drillmn300 ]
    Drill
    David Bolt
    Champaign, IL
    USBC Silver Coach
    IBPSIA BOD
    IBPSIA Advanced
    Technical Certified
    Pro Shops
    Re: Ball Wheel
    Welcome to the club. My house has 16 converted A2s and 8 Jap A2s. Had a ball wheel break close to a year ago. Had a guy come in and weld it, but it only lasted about 6 months.....Had a different guy come in and weld it again so we shall see how long this one lasts. We did the welding while the ball wheel remained in the pinsetter. Thought that it would make the job easier than taking one out. Our converted A2s were made in 1960. I think I would be safe to assume that being made in 1960 and 1961 (yours) would be the reason why they broke. They are old!!! HA.
    Here is an old thread about the same problem. Enjoy!!
    ....rob
    Ball Wheel Thread....Click Here!
    Space is the Place!
      Re: Ball Wheel
      Yup..Been there.
      I have come up with a theory as to what might cause the wheel to break. Helper springs. The springs increase the pressure on the wheel causing it to break. The only one I had to break was one with the quality double spring kit on the rods.
      With more oil being put on the lanes, and heavier springs being installed on the lift rods, this problem will probably become more common. [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img]
      Food for thought..
      Adam D.
        Re: Ball Wheel
        Yep, I have the dual spring kit on mine and I really wish they sold them. It eliminated most of my ball problems but I can see where it would cause excess pressure on the wheel.
        Drill
        Drill
        David Bolt
        Champaign, IL
        USBC Silver Coach
        IBPSIA BOD
        IBPSIA Advanced
        Technical Certified
        Pro Shops
          Re: Ball Wheel
          I have seen this in two places. At one of them it was so often I just started welding them in the machine. [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img] I wonder if you guys could produce some serial numbers. I wonder if there was a bad run on ball wheels.
          Please buy MADE IN USA!
            Re: Ball Wheel
            Mine was on a 58,000.
              Re: Ball Wheel
              Mine are 66,000 and so far I have only seen it happen to 1 machine. I did go through the rest of them with a fine tooth comb and didn't see a thing. How many sections is the original wheel in? By the way they are real easy to weld and get a permanent fix on if they are removed from the machine.
              Drill
              Drill
              David Bolt
              Champaign, IL
              USBC Silver Coach
              IBPSIA BOD
              IBPSIA Advanced
              Technical Certified
              Pro Shops
                Re: Ball Wheel
                I had one break 27000
                John B
                just fix it
                  Re: Ball Wheel
                  Well, acording to the serial numbers...that would of been one hell of a bad run!!
                    Re: Ball Wheel
                    had one break about 4 years ago i guess nothing lasts forever.
                      Re: Ball Wheel
                      Just to let you know, we have machines ranging in number from around 5500 to 12000 and have never had a ball wheel break or split.
                        Re: Ball Wheel
                        Been that route too. Although I wasnt the one to change the ball wheel. Had the broken one welded but it was out of the machine and a new wheel was installed. Now I have the welded one as a spare. So far havent had to use it.
                        msbowl
