Is it possible to replace a d-shaft assy while it's still in the detector?I have a machine that once in a while it will set pins while being held up on the lowering hook,problem started after a clutch reset lever cracked at the weld,i replaced it and adjusted the dashpot but every now and then it want's to set pins the wrong way.,all else seems to be fine,i am thinking d-shaft has a problem,if at 270 i move the d-shaft inward i can get the lowering hook to slip off and it seems to easy to get it to slip off.I see nothing binding in the detector,no excess oil to make something slip off and blocking surfaces are all good.Now it's starting to bug me.So...am i thinking in the right way...D-Shaft assy?,worn out spring or bent shaft?
Adjustments are on yet it wants to slip off.It's bugging me alot more now!
