NO POWER CAPTIN
  • NO POWER CAPTIN
    Hi Again,
    we are at our wits end, i am working on A-1 pinsetters, weather i turn on the machine from the back our the managers box i cannot get the machine to power up. i have changed the Motor Start Relay and re-wired the motor start relay's power input. Any Thoughts [img]/content/btubb/images/%%GRAEMLIN_URL%%/shocked.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/shocked.gif[/img]
    Re: NO POWER CAPTIN
    Here is the psot from the referance are of Bowltech, this should get you started.
    Bowltech Referance
    If this don't help post back,
    Peanut
    Peanut
      Re: NO POWER CAPTIN
      ThankYou
      Just before you replyed to my message i found the problem the wire that sends power to the masking swicth on/off was bad i guess there was a internal break or something. But i did like the whitepaper reference you gave to me thank you all [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
        Re: NO POWER CAPTIN
        I would have started with checking the Dilithium crystals. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
        billman
        let me be myself
