Machine speed
  • Machine speed
    I have converted-A2s and I am trying to slow them down (to a crawl). Any suggestions where I can find the necessary gearbox motor pulleys?
    I've got your second ball!!
    Re: Machine speed
    grainger carries all of the motor pullies you can think of. do you want "a" speed or "jetback" i'll post the # for the "a" pullies tomorrow for you if you'd like if you want "jetback" pullies...i've got 24 of the that i'll give you cheap.
    alex
    Cloth: ShamWow!
    Machine: Johnny 5
      Re: Machine speed
      Shame ,
      I'm interested in the 24 Jetback pulleys if Nostalgic Mech doesn't want them.
        Re: Machine speed
        Thanks shamefowjze... I will check with Grainger and see. I still have some other things to look into before I can order them. Mainframe, if you want them be my quest.
        I would love to get that number though. Thanks again.
          Re: Machine speed
          Quality makes a special pulley which is what I would recommend since it slows both the gear box and the elevator down(remember the jetback pulley acually speeds up the elevator).
            Re: Machine speed
            mainframe
            I will have 20 jetbacks in about 3 weeks if you want them
            Peanut
            Peanut
              Re: Machine speed
              Sure could use that grainger number,i need pullies.,there has got to be a cheaper place to get them,i think they we're about $65.00 a pulley in the parts book.Came across a place called Phoenix pullies and idlers but i like to price shop.If i remember correct i have 7"(or close to)for my pulley size and want to go slower,is the 6.80 next in line,i have a 4.5" (or close to)on a lane now and it's tooooo slow.,bowlers will not like that!
              Grainger number pleeeeease.TY,TY,TY.
              It's late so i can't remember my pulley sizes correctly.
                Re: Machine speed
                Just remember that if you change the motor pully to change the gearbox speed, you should also change the motor to gearbox belt, too. They are different lengths for the different pullies; it makes a big difference especially if you have the floating motor mount.
                Learnt that one from dire experience.
                mick
                The long term cost of inaction is greater than the percieved short term convenience.
                  Re: Machine speed
                  I have 6 3/4 inch pullies on now and want to go slower,tried the 5 1/4 but too slow,is there a better size to use?
                  I can get a 6 inch for about $12.00 and a 3 inch for about $5.00.
                  Right now i don't like the speed of the 6 3/4 inch pullies...need slower size.
                  Grainger number???Quality number???
                  Thanks! [img]/content/btubb/images/%%GRAEMLIN_URL%%/usflag.jpg[/img]
                    Re: Machine speed
                    Gearhead:
                    You're putting yourself into oddball land now ...
                    6+3/4 is jetback size pulley (actually 6.8, but who's counting)
                    5+1/4 is a Model "A" pulley (way too slow, I agree)
                    Anything in between, you may have trouble getting the correct combination of belts to get the job done ... so be sure that you can get belts to provide the right tension before you buy a ton of pulleys.
                    I'm puzzled ... an A-2 running jetback speed should be smooth as silk with the new MD cam profiles. Jetbacks, yes the deck does shift hard (almost slam), but that's with the original A style cam installed, and sped up.
                    The elevator ... another story ... if it's a-2 with a jetback pulley(3.5), the turret's gonna run warp speed. Quality Made a jetback special (6+3/4 with a 3" elevator) to slow down the A2 g/b without speeding up the elevator.
                    Hope this is of some use:
                    Kevin
                      Re: Machine speed
                      We have used a Browning AK 6.1 pulley to the gear box and a Browning AK 3.0 for the elevator.
                      This combination can be used on both the A & A2 pinsetter without any cam or belt changes for the A pinsetter. The A2 needs a A-62 belt to the gearbox. Any bearing shop that carries Browning pulley & sheeves can supply these pulleys. One thing to consider is to drill and tap for an additional set screw 90 degrees off the keyway. We normally will take a drill and ding the motor shaft for the new set screw. We have found out that the two seperate pulleys can come loose once in a while unless you have this double set screw setup. We have installed this pulley setup on 600 - 700 pinsetters.
                      EDJ
                        Re: Machine speed
                        the one thing I do is leave the motor to gearbox belt on the loose side so if there is a deck jam there is less of a chance of breaking something or twisting something if the deck jam or turret jam switches fail [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img] and the clutch pulley seems to last longer. GROUCHO
                          Re: Machine speed
                          I have the 3" pulley for the motor to elevator but the turrets run at warp speed,i'd love to slow down the turret speed a bit plus slow down the pit speed.
                          I know some of you have changed pullies to do this but which ones do i change to slow them down.
                          Maybe i'm just used to the place i was at,they might have had the model-a pullies so watching my machines run here look like they are too fast.
                          Pulley advice for changing turret/pit speeds??
                          Reducing the speeds will help in the long run on parts,etc.
