Okay Guys, I am running A-1's and i have a machine that will not quit going out of range, i have cleaned the gearbox and checked and rechecked my detector but it just goes out of range too much during open & league play. Please help [img]/content/btubb/images/%%GRAEMLIN_URL%%/usflag.jpg[/img]
Out Of Range
Re: Out Of Range
when the oor happens is there actually an oor or is it detecting standing pins or a strike as an oor?
alexConditioner: Pantene Pro-V Brunette Expressions with Color Enhancer
Cloth: ShamWow!
Machine: Johnny 5
Re: Out Of Range
Two things to look at, for starters:
Put machine at 180, waiting for pins. Check your dashpot adjustment (clutch latch face should be aligned with the center of the X pin in the reset lever) If too low, clutch could disengage at wrong time (270) Adjustment is made by loosening allen screw in collar and moving it on time delay stem. If latch is too low, collar is too high.
While you're there, check for the 1/4" gap between the release lever and the stop arm. Too big of a gap can cause clutch to disengage at 270:
Hope one of these helps:
Kevin
Re: Out Of Range
Tony, You might have to change your detector. If the link assembly (12-100350) is broken your pinsetter will tend to stop at 270. Paul from HarborI'm going fishing and camping!
Re: Out Of Range
How long has the machine been doing this. And was there any change in parts prior to it acting up. Try to retrace what happened and ask everyone who works in back if they worked on that lane.
msbowl [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
Re: Out Of Range
The only other person that ever did work on the machine no longer works in our center , i do know that he did NOT do any preventive manitance on the machines. so i truely have know clue what he has or has not done to the machines... I have been the only person doing the machine work since ...
Tony [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img]
Re: Out Of Range
I agree with Keven...check to make sure the latch is not relocking under the pin on the reset lever at 180...also, when you adjust the dashpot...make sure the machine is actually at 180...if the gearbox clutch is out of adjustment, you may not be getting the proper adjustment...model A's are not as picky on this adjustment as A2's are...but it's worth checking out.
