Here is one we are working on. The deck lowering hook on #15 hits the pinsetter frame during a forward stroke. It has hit the frame so hard that it put a dent into it. The deck lowering hook is a new one, but it is not Brunswick. We purchased it from another supplier. When it hits the frame, the whole gearbox moves about a half of an inch. Boy, that is scary. Anyone have any similar experiences? Thanks for reading.
Deck lowering hook hits pinsetter frame
Re: Deck lowering hook hits pinsetter frame
Your lowering hook is set too high. On one end of the shat where the hook mechanisim is, there is an adjustment bolt. Follow the link into the detector. You should see about a 1/8" gap between the block on the lowering hook selector, and the lowering hook controller.
Adjust until you have a 1/8" gap at 0 degrees.
I have 1 machine that has a dent in it from this and this was the cause.<span style="font-style: italic">Sometimes it is best to use good advice from many individuals to achieve the ultimate result.</span>
I would ask why is it new? Because the old one broke? If it did, you are looking at a problem with the eccentric ring itself. It may have deformed when it broke the lowering hook you had on before. But the real question is why did the old one break? Usually I find the eccentric ring hangs up on the crank assy due to sludge that has built up over the years or from lack of lubrication has caused the crank assy to become scarred. I would remove the eccentric ring and clean and inspect the crank surface and see how it looks. If everything is in good shape, clean everything up and replace it. Keep everything well lubed and your hook should never hit the frame again...TSM & TSM Training Development
Gentlemen:
JBEES has this one nailed. When you break the hook, the pipe will be dented. This is from the eccentric rotating upwards at 270 setting pins, owing to a slight bind in the assembly. Indeed when making any adjustment on the eccentric, I slowly run the mch. through the pinsetting cycle, to ensure the ring moves freely. To tight on the U bolt, on low linage machines can also cause the problem.
Roscoe.rfm
I agree...however if it's been replaced and lubed...I'd look at the adjustment of the ecentric ring itself...if it's not ajusted properly...the hook will hit the frame...that's likely what broke it in the first place.
