Pastic Twister pins
  • Pastic Twister pins
    Am using pastic Twister pins in A-2 machines and am having touble getting them up the cross conveyor.
    Intersted in knowing what people are using to clean them.
    Canadian tech
    Re: Pastic Twister pins
    Try Ed Fox's turn pan wipes.
    They should help.
      Try this kit. Make one if you can't find it.
      Photo credit - masternut
      Hope you don't mind me borrowing your pic masternut.
